Discuss Adding a relay to the timer on my submersible 1/2hp 230v pump. It was recommended by the timer manufacturer. in the UK Electrical Forum area at ElectriciansForums.net
Pardon the blunt reply What purpose do you need the relay for???Looking for advice to add a relay to a well pump timer. 1/2 hp 230v submersible @750’. The timer is rated at 10amp.
[automerge]1578238119[/automerge]
Does anyone have any recomendations?
Change the timer switch for a suitably rated oneTo buffer the draw on the timer switch.
When you say "buffer" what exactly do you mean? reduce voltage current or what exactly?Manufacturer of the switch says that it is suitably rated however recommended a relay in between switch and pump
May be Inductive as it's concerned with a SP motor?Is the 10A rating for a resistive load.
I have to agree with Buzz what will be the purpose of adding a relay to a timer since the timer starts and stops the motorIn the USA the UL-approved ratings for relays and relay-controlled outputs have both current and motor hp given for any unit, similar in intent to our resistive and inductive ratings. Although the 1/2 hp motor uses less than 10A, the fact that there's no motor rating shown, and the manufacturer suggests a relay, implies that the 10A is indeed for resistive loads only and the timer output relay might have a short life switching the motor load.
I'm not quite sure what the original question was: Any electrical control gear seller will have suitable contactors and enclosures; I don't know that there's any point in recommending a specific product.
Why is that WestyThe timer will switch a suitable contactor/relay to control the pump. The 10A rating is likely to be a resistive rating and not inductive which would be much lower.
Reply to Adding a relay to the timer on my submersible 1/2hp 230v pump. It was recommended by the timer manufacturer. in the UK Electrical Forum area at ElectriciansForums.net
