Hi all
I have been asked to do some outside lights with a PIR and an override switch inside.
I believe the best way is to run from consumer unit L + N to switch and then a 3 core to sensor (PL,SL and N) and then SL & N to lights. Someone has already ran the SWA cable outside (under the driveway)which is a 3 core so I can use braiding as the Earth. Can anyone else suggest any other alternatives or is this the simplest way?
