Adding a zone valve | on ElectriciansForums
Discuss Adding a zone valve in the Central Heating Systems area at ElectriciansForums.net
Somerset
Im working on a heating system that's currently all wired into an ufh wiring center. Another zone on a different floor is being installed of heaters (no actuators).
My question is, would you wire the new zone valves and stat into the existing wiring center and use one of the free actuator terminals to connect it all up as there's no other space or install a serperate wiring center next to it?
Forget this thread please. I've worked out what I need to do, which makes this thread make no sense to anyone Delete please
Reply to Adding a zone valve in the Central Heating Systems area at ElectriciansForums.net
UFH and zone valves help? Hi all Got an existing combi with 3rd party controls. There is a towel rail zone with 2 port valve and UFH manifold with...
Scott_D
3 core wouldn't, but 3 core and earth should I think. The live from the UH4 could feed both the brown and grey of the valve.
