Adding an additional light to an existing electrical ring circuit | on ElectriciansForums
Discuss Adding an additional light to an existing electrical ring circuit in the UK Electrical Forum area at ElectriciansForums.net
Kent, UK
I have a working circuit setup connecting the CU to a switch and light. I want to add an additional light to this circuit, do it use the Brown or Black as live. See images attached of existing termination and loop.
[ElectriciansForums.net] Adding an additional light to an existing electrical ring circuit
Do you want your extra light to be separately switched or come on when that one is on?
Are the 3 wires taped up in the first picture new ones you have added?
The short answer is (with the power off) you need to see what (if anything) the brown wire is connected to at the switch.
The first picture (the existing light) looks as though you have a neutral (grey sleeved blue), a switched live (black sleeved brown) and a might-be-permanent-live (brown). But the function of the brown wire can't be verified from the photographs.
The 2nd picture appears to just be a junction box extending the cable.
Reply to Adding an additional light to an existing electrical ring circuit in the UK Electrical Forum area at ElectriciansForums.net
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
