Adding capacity to existing system | on ElectriciansForums
Discuss Adding capacity to existing system in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
dek69
Hi all.
I am intending to expand a 1.2kw system to just under 4kw.What is the correct procedure to for informing relevant authorities,etc.
I have installed lots of systems but not added to an existing one.
Any guidance would be appreciated.
Speak to local supplier.. They are normally pretty helpful.. SSE anyway. They should be able to advise on demand available to premisis. Best case they will come out and just uprate the cut out fuse.. Worse case dig up your drive a run new supply cable in for increased load... Dont just increase the fuse capacity yourself. Good luck.
Reply to Adding capacity to existing system in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
Hi everyone, I am new to photovoltaic system installation, can you guys give me some advice. Currently I plan to purchase a Maysun Solar 800W...
