Adding central heating pump to Immersion circuit? | on ElectriciansForums
Discuss Adding central heating pump to Immersion circuit? in the Australia area at ElectriciansForums.net
L
lawsonium
Hello,
I have a hot water cylinder with an immersion heater which (as far as I can tell without looking further) is on it's own dedicated circuit. I'm not at home right now so can't look up the circuit breaker rating (I'll look this evening).
I have a wood burner with back boiler and intend to use it to heat (indirectly) the water in the cylinder and eventually about 3 or 4 radiators upstairs.
My question is, when I come to installing the radiators is it possible to extend the radial immersion circuit to run the pump?
I would prefer this option rather than running another circuit.
I would appreciate some expert advice. Thank you in advance.
Matt.
Reply to Adding central heating pump to Immersion circuit? in the Australia area at ElectriciansForums.net
H
Central heating system cleaning Hi all, I have added a bottle of Fernox F3 into my towel radiator upstairs, I have run the heating for a good few...
Happyharry
H
E
Can a HW cylinder be used as primary heat source for CH only? Hi, I would like to know if a HWC can be used as a primary heat source for a new...
eric12
E
