Adding extra chime to mains wired doorbell | on ElectriciansForums
Discuss Adding extra chime to mains wired doorbell in the UK Electrical Forum area at ElectriciansForums.net
West Midlands
Hi
I have a mains wired doorbell with the chime in the hallway. Parents are elderly and dont hear the bell all the time. I want to run two wires from the hallway chime into living room and add another chime there. Does the new chime need to have built in transformer does it not require it?
Current set up is a transformer by the fusebox and the chime has one wire to it and another to the push button. One wire from the push button the transformer to complete circuit.
One transformer for two chimes
But
I have found that many bell transformers don’t have enough output for two bells. So, you may find that you need to replace the tranny. Try it and see if it works, but I too would go for a wireless jobby.
Connecting two chimes with built in transformers to the same push is not a good idea. They would need to be connected so that booth transformers are phased together, and not one 180 degrees out from the other, and unless the voltages of the transformer secondaries are identical, there will be a constantly circulating current through the two chimes, which may make them buzz. you could probably solve this with a couple of blocking diodes, but then the chimes might not perform as intended.
You can connect two chimes in parallel with a transformer by the CU, as long as that transformer can supply sufficient power to supply your chosen two chimes.
Thanks. So just buy a normal chime like i got already without a transformer built in. Wire it from the current chime. As long as transformer i got currently has sufficient power. Ill check it tonight and advise what power it has.
Most standard bell transformers are rated at around 1amp. Enough for one bell. Adding a second bell may be too much.
And the length of the wiring has an effect too. But see how you get on. Be prepared to have to buy a bigger transformer.
Quite honestly you’d be better off ditching the plan to extend the existing bell. Get a wireless one with two (or more) soundest. It will probably be cheaper and easier.
Reply to Adding extra chime to mains wired doorbell in the UK Electrical Forum area at ElectriciansForums.net
How about one of these ? No supply needed and has the benefit of having an array of different knocks for all types of moods.
Most RC Model systems work on a bus system now days so minimal wiring, Transmitters are available up too twenty channels and more so that is not...
