C
cosmonaute
Hello
I have a spur off the ring main via a junction box which supplies a double socket in the kitchen. I want to add a spur from this to supply a single socket for a fridge.
Is it possible to add a fused connection unit into the existing spur wiring prior to the double socket , then take a spur straight from the double socket to the single socket for the fridge ?
Or can I replace the double socket with a FCU and single socket combination (which should fit into the existing double back box) , then take a spur for the fridge from that ?
added diagram
David
added diagram
David
