Adding power to the loft | on ElectriciansForums
Discuss Adding power to the loft in the UK Electrical Forum area at ElectriciansForums.net
skyrat
With reference to the attached file (LoftSocket.pdf)...
I need to add power in the loft for a TV amplifier. In previous houses I tapped into the light ceiling rose which was easy enough because the lighting circuit was a 'looped circuit' so there was a permanent live available (see pages 1 and 2).
But in in my new house, the lighting circuit is 'single and earth' so there is only a switched live available (see page 3). Therefore the amplifier would only work if the light was turned on !
So, I plan to add a mains socket to the ring main. I found two 2.5mm wires that go to a socket in a bedroom (see page 4).
Is it correct how I plan to wire the loft socket (see page 5) ?
  • LoftSocket.pdf
You can carry out this work if you are classed as "competent" to carry out the work, ie qualified and experienced. Obviously you will need to test the circuit once it's modified, and produce a minor works certificate for the addition.
Reply to Adding power to the loft in the UK Electrical Forum area at ElectriciansForums.net
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
