Adding single pole switch | on ElectriciansForums
Discuss Adding single pole switch in the UK Electrical Forum area at ElectriciansForums.net
Arizona
I am trying to install a new fixture and want to bring power to it by adding a single pole switch to a box containing another single pole switch. I believe its the end of the circuit as both black and neutral wires are hot. How do i add the new switch to it? I made pigtails, ran them from the black feed to each switch, joined the neutral from the feed and the neutral coming in from the fixture, and hooked the black coming from the fixture to the available post on the new switch. Im getting power at the fixture, buts its not working or the light doesnt turn on. Have i made a wiring mistake or do you suspect there is a problem somewhere along the circuits line?
Reply to Adding single pole switch in the UK Electrical Forum area at ElectriciansForums.net
In TN-S systems, you shouldn't isolate the neutral in a 4-pole isolator. Connecting neutrals to a dedicated terminal is acceptable and safe...
