The existing underfloor heating in my flat is over 20 years old and is under or embedded in the concrete substrate under wooden flooring.
It is connected to the off-peak/Economy 7, comes on at night and stores the energy to release throughout the day. It is controlled by a 'weather-watcher' thermostat outside on the balcony that switches it on when the temperature drops to a certain level.
  • Would it be possible to disconnect it from night time off-peak and connect it to peak so I can switch it on at any time?
  • There are currently no thermostats inside the property so would it be possible to disconnect the outside 'weather-watcher' and retrofit a thermostat inside?
  • There are fuses for the underfloor heating in each room - would it be possible to connect a thermostat from the fuses to put a thermostat in each room?
Thanks in advance for any advice!
London
United Kingdom
Adding Thermostats To Existing Underfloor Heating
DIY Electrical Advice
Thread Tags
Tags Tags
heating
Phlpjns,
