B
Blacktail
Feeding two outbuildings by overhead cable from TNCSsupply. Building one, steel framed barn,earth floor etc. Building two, stableblock, concrete floor/block walls and steel roof frames. Approx 20 and 30m respectively from supply.
For all obvious reasons going to TT each building and fiteach with its own DB. Sub main will run fromsupply to outside of first building to junction box. Here it will split to feed DB-1 and feed, via overhead, to stable block and DB-2.
Do i need to consider the “ daisy chained ” feed from buildingone to building two, to now be a TTsupply and therefore require additional protection. It won’t be supplied from DB-1 as it willsplit at the junction box.
Armour/cpc continuity will be maintained through junctionbox to downstream of DB-2. Bounced thisof my “Approver” and they say second feed requires additional protection as itis now TT. Not sure.:crazy:
