additional pir sensors in ceiling | on ElectriciansForums
Discuss additional pir sensors in ceiling in the UK Electrical Forum area at ElectriciansForums.net
T
thenugnug
Hi all just a quick question. i need to add a couple of additional ceiling pirs can you just do this by using 3 core cable and link your live neutral and switch live to each additional sensor?
Reply to additional pir sensors in ceiling in the UK Electrical Forum area at ElectriciansForums.net
That will work fine as long as the Pirs use relay switching, some don't.
I would use the Switch & Load 16A - https://www.quickwire.co.uk/product/switch-load-16a/ Designed to do the same thing as the ceiling rose in...
