Additional protection by means of RCDs | on ElectriciansForums
Discuss Additional protection by means of RCDs in the UK Electrical Forum area at ElectriciansForums.net
Danny Huht
Hi,
I'm an electrical apprentice and was just wondering if anyone could explain additional protection using RCD's?
Hi mate. Have you tried Google? Lots of knowledge there.
Is there something specific you would like to know and that is why your are asking the forum?
I think the OP is/was just trying to understand the meaning, I could be wrong but that's my take on the question.
Worth keeping it at Home for times just like this one
I don't think he means he has his own personal copy. He is an Apprentice, and I take it he means that he has access to a copy at the training centre when he needs it but doesn't personally own a copy.
Hi,
Danny try and get access to the Trainee area, not sure what the criteria is, plenty of knowledgeable people/Mentors there only to willing to help, plus you won't get any mickey taking, however daft the question may seen to you, give it a try.
Yes mate you probably are correct, from catching from some of the replies, that's how I read the situation, I don't use my copy much now I am retired, but reluctant to give it away as I like to have a quite read sometimes, just to exercise my brain once in a while, Red Wine permitting that is.
Just a bit of info from the regs.
411.3.3 Additional protection
In a.c. systems, additional protection by means of an RCD in accordance with Regulation 415.1 shall be provided for:
(i) socket-outlets with a rated current not exceeding 20 A, and |
(ii) mobile equipment with a current rating not exceeding 32 A for use outdoors.
An exception to (i) is permitted: |
(a) where, other than for an installation in a dwelling, a documented risk assessment determines that the RCD
protection is not necessary, or
(b) for a specific labelled or otherwise suitably identified socket-outlet provided for connection of a particular |
item of equipment.
NOTE 1: See also Regulations 314.1(iv) and 531.2.4 concerning the avoidance of unwanted tripping.
NOTE 2: The requirements of Regulation 411.3.3 do not apply to FELV systems according to Regulation 411.7 or reduced low
voltage systems according to Regulation 411.8.
NOTE 3: See Appendix 2, item 10 in respect of risk assessment.
415.1 Additional protection: Residual current devices (RCDs)
415.1.1
The use of RCDs with a rated residual operating current (lAn) not exceeding 30 mA and an operating
time not exceeding 40 ms at a residual current of 5 lAn is recognized in a.c. systems as additional protection in the
event of failure of the provision for basic protection and/or the provision for fault protection or carelessness by users.
415.1.2 The use of RCDs is not recognized as a sole means of protection and does not obviate the need to
apply one of the protective measures specified in Sections 411 to 414.
item of equipment.
415.1.1
Thanks very much, should help a lot mate
Reply to Additional protection by means of RCDs in the UK Electrical Forum area at ElectriciansForums.net
Thanks for the replies, I appreciate it.
Duh!!! Just re-read Op's original post, it was converted to a RFC!
