danesol
For installers really and what approx price would you say for this ?
To add 4 x 280w ( ideally ) or 6 x 180w panels on a new roof (30deg, no shading ) facing due WEST in Cheshire using a 2nd INVERTER and 2nd generation meter to give a further 1.12kwh array to an already existing 2.88kw South facing system.
Connection would be directly into the currently Henley block, utilising ~20mtrs of armoured (AC) cabling from roof, which btw is a straight run through the gable end wall straight down to the Henley Block in wall cabinet.
What would be the best combination of kit to use ?
What sort of ROI would you be looking at and what level of generation would it gain ( It was assumed around the 680kwh/yr fig ?? )
What target dates are there with this in mind too ???
Please feel free to pm a quote should you not want to display publically
