Additional Sockets | on ElectriciansForums
Discuss Additional Sockets in the Australia area at ElectriciansForums.net
R
Rammie
Hi all
Still getting use to this work....been asked to install 2 double sockets into a loft but no ring main running through loft area it all appears to run mid flooring for upstairs. Only lighting circuits in loft and all running through 20a junction boxes, I would have expected to see 5a? Any suggestions for how I might overcome this in order to install sockets? :confused:
Many thanks
Rammie
Steepest learning curve of my life....!
Hi all
Many thanks
Rammie
Can you spur off a socket in a room below? use an fcu if you need 2 sockets though, any amp junction box can be used for lighting provided its up to the job of handling the design current, normally its only 5 or 6 amp for domestic lighting
Thats pretty mormal Rammie
Depending on your load required,you may not need a ring in the loft
A radial run up through a suitable cupboard off a socket then a fused spur feeding the attic sockets may suit
Beaten in a close finish
I concede
Reply to Additional Sockets in the Australia area at ElectriciansForums.net
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
