addressable fire alarm commission | on ElectriciansForums
Discuss addressable fire alarm commission in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
L
leekemp85
How hard is it to commission a addressable fire alarm I have been quoted £400 per day(40 points a day). is it possible to do it myself
Reallly depends on system you are working on and what needs to be addressed. If it is relays and interfaces it adds time esp if you are programming them up. Are you using a lap top or via the panel. Also if the wiring is not ok, it can make a difficult as fault finding can eat up time. Good money though for a days work.
To set up the text strings,zonal assignments and any cause and effect programming + testing - 4 or 5 per hour isn't unrealsitic.
How many devices are there?
Is the panel addressable or conventional?
Make of panel?
£300 - £500 is the normal day rate for commissioning, remember that the commissioning could include several hours of writing O&M manuals & autocad drawings dependant on the system size.
Make of panel?
he has already said it is addressable
Reply to addressable fire alarm commission in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I challenged a council on having the same system installed in an HMO. One consideration is if the flats/escape route were made to The Building...
Hi All, I am looking to start installing commercial fire alarms, I want to be able to design, install and commission. I am a member of NICEIC so...
