hello i quickly run through a senario and hope that sombody can point me in the right direction>
a few years ago i installed a ADE optima compact alarm to a freinds house. its worked fine for 5/6 years, just before christmas last year he came back from holiday to find the bell/strobe box flashing, the strobe flashes and a red LED also flashes once per second approx.
i thought it was the entry alert to warn the owner that the alarm had been triggerd, so we went through a few things even doing a factory reset to find that the strobe kept on going..
ANYWAY! I rang the manufacturers tech line and he advised me that he thought it was a new bell box required. so i ordered one.
I ended up with a intellisense AG6 external sounder and strobe. with the following conns>>
ST- / R- / SW- / V+ / V-
However the instruction that came with the AG6 state>>
TR- / V- / ST- / V+ / S-
Does any body know if the above is compatible with the above mentioned alarm system ?? which has the following connections.
strobe+ / strobe - / T / A / V+ / V-
i disonnect the v+ and the battery backup installed on the bell box and the strobe still flashes until i disconnect the strobe + wire. this leaves me thinking that i may be chasing a red herring and there is actually some other fault, i.e main pcb?
any experts out there??
SORRY FOR VERRRY LONG POST.
