R
rick.oshea
can anyone help
I want to calculate a main earthing conductor for a three phase supply using the old adiabatic equation.
I'm struggling to work out what value of I to use. If you use 230V/0.35 (for a TN-C-S) then you get 657 amps.... if it turns out that Ze is lower, the fault current is going to be higher, so what do you do?
And again with time, do you use 0.1 or 0.4?
Any light shed would be greatly appreciated....
Cheers
Cheers
