Adiabatic Equation | on ElectriciansForums
Discuss Adiabatic Equation in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
danielspencer
Hello
Does anybody know if 'I' in the equation relates to PSCC or PEFC.
GN3 seems to point to PEFC, but reg 543.1.3 seems to suggest PSCC.
Any ideas?
I would agree its PEFC as you will be working out the size of the earthing conductor so you need to how much current would flow in it not anything to do with another phase or nutural
Regards
AJ
It depends on the type of earthing system I = U0/zs where Zs = measured or designed or I can be measured as well in TN-S I = pefc.
For TNC-S I = pefc and also Pfc as both earth and neutral are combined at supply.
Reply to Adiabatic Equation in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Having some issues with my companys fluke 1662/1663 tester. Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
In the UK the safe current for a cable is determined by considering how it's installed, eg under insulation, or buried in a wall, or in conduit...
