Ads
L
lofty84
Ive been asked to describe ADS, does anyone know what ads is short for so I can look it up Thanks.
aotomatic disconnection of supply. this occurs when a fault trips the protective device.
at least. that's if it's not those things stuck up in the local shop for missing cats, local handyman, etc.
It used to be EEBADS (Earth Equipetiential bonding and automatic disconnection of supply ) but changed when 17th came out i think it was then , now it ADS and as the other guys have said its Automatic disconnection of the supply
thanks for the replys.
Ive been trying to find out why a socket in a bathroom provides protection from electric shock but havent had much luck so dont know how to describe why?
not quite with you there. socket in a bathroom is a no-no. unless 3m from bath, where bathroom is perhaps a bathroom/dressing room. would have to be RCD protected, so that's how it provides protection from shock, as well as the ADS due to presence of a fault
M8 tell me do the regs mention a lenth of lead when the socket is 3m from the bath? just thinking of something with a 3m flex on it. Looked at Spanish regs on bathroom zones and no mention of lead lenth, just the zones and what you can put in them.......Strange!
