Hi All, been a while since been on. Life very hectic.. Hope all are well.. Anyway..
Very regular customer tied into an exorbitant ADT contract. Last time she called them out was to A) remove magnetic door contact from door and B) return and refit contact on new door.. Cost +£1000.00 yes over a grand..!
Situation now is old warped door in cellar. Gap between wired contact and the secondary contact is only 7mm at most but alarm won't set. Wedged a bit of wood to keep the door tighter and alarm is now on.
Is the non-wired part of an ADT door contact ok to remove and put a spacer underneath...? The wired part will upset the tamper and cost silly silly money I would think.
There is no secondary wireless tamper I may not realise is there...
Thoughts appreciated.. Ta.
[automerge]1572995505[/automerge]
This is the proximity key if that helps at all...
And anyone who can give a surefire answer gets half of the callout fee - I will charge a mere £600!!!
[automerge]1572995784[/automerge]
I did put a photo on but it has disappeared with the 'posts merged' malarkey...
Proximity is a tiny green tag with an almost WiFi symbol.. approx 23mm by 19mm ish!! I guess that won't help though and the prox keys are the prox keys...
