Advanced Electronics MX4100 Fire Alarm network | on ElectriciansForums
Discuss Advanced Electronics MX4100 Fire Alarm network in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Essex
Hi, I now this would be best in the fire alarm forum but I don't have access.
Does anyone know what cable should be used to network a planet and remote terminal. We're doing the first fix for the fire alarm and the drawing says 2xFP200 1.5 t&e. The installer guide doesn't specify but mentions twisted pair. I would have expected it to be a belden.
Then ask the person who designed the system/did the drawing.
If the drawing is wrong then get an amended drawing issued before you proceed.
Cheers, makes sense, fire rating for comms otherwise you'll be repeating nothing!
The job is about to be plastered and decorated, it would be a shame havering to add something surface just if the designer missed something.
The cable must be fire proof FP200 2 core+E 1.5mm One FP200 cable for 24 supply, and one FP200 cable for data.....Important note, do not use 4 core FP400. This may corrupt data, and the repeater will not work.
Reply to Advanced Electronics MX4100 Fire Alarm network in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
