M
mort2376
Having to pick up from where a previous electrician has done a runner on a new build.
Underfloor heating system installed with 2 manifolds 1 upstairs, 1 downstairs.
Previous electrician has put in a cable from the upstairs manifold and pump back to boiler, but has not put one in for the downstairs !
Owner has moved in as plumber has got the system working by putting everything on plug tops and plugging them in !
They have got Honeywell DT92E wireless stats 1 for upstairs one for downstairs. Because there is now no control wire to switch the downstairs manifold pump on and off my question is can you use 2 recievers to 1 wireless stat ?
I know 1 reciever can have multiple stats but can you go the other way round. That way when the downstairs stat calls for heat it switches the boiler call for heat on with 1 reciever and the pump with the other ?
Have tried phoning Honeywell Tech support, but apparently due to a problem they are not taking calls at the moment.
Anyone tried anything similar ?
