Advice and information | Page 2 | on ElectriciansForums
Discuss Advice and information in the UK Electrical Forum area at ElectriciansForums.net
Brunel
LEEDS
A bit of background info. I live in a flat complex, approx. 6 mths ago some building work was carried out which necessitated removal of some external light fittings pending full completion of the work.
An electrical contractor was employed for the removal and making safe, until the work was completed.
Six months later, for reasons as yet unknown, the work has not been completed and the temporary electrical work is still in situ. I and a few other residents have queried whether the temporary electrical work is safe, the cables are of course outside, and are only covered in plain brown electrical tape, please see attached picture 1:
[ElectriciansForums.net] Advice and information
Today the electrician was on site for other work and also added some extra tape and a plastic bag to the above cables and to another cable in a different position. These cables are within touching distance of anyone walking past. Picture 2:
Picture 3:
I realise that the work is only temp. Do I have good grounds in raising a serious safety issue to the management company?
Thanks for any response.
I don't think it has been mentioned but those cables may very well have been made safe by disconnection and the electrician be taping them up to stop corrosion
If that is not the case then the comments previous may be justified
Good observation. These cables are all LIVE, they used to feed a permanent outside light and an emergency light. They are connected direct to the internal 24Hr. lighting circuit.
While the electrics don't look too clever I think I would be questioning the suitability of the fixings that are holding that steelwork
It's a complete bodge , if there is no plate on the inside those bottom bolts are on the edge of the bricks , OK it might have a support upright , but it is not ideal.
Reply to Advice and information in the UK Electrical Forum area at ElectriciansForums.net
To be honest I am in NC and I’ve always used old blankets to cover all my well and never had a problem. Much simpler and has worked every winter...
