T
The General
I've been asked to go out and look at a job - wiring in a Heat Mat to go under some tiles (bathroom I think, but not been out to visit yet.)
Firstly, I've never done one of these before, so any pearls of wisdom would be greatfully received.
Secondly, I'm assuming that a 'Park Home' (static caravan) will come under the Special Locations section - or is that just 'mobile' caravans?
Obviously I'll need to read the instructions that come with the mat/control unit, but I'm guessing that it'll need a (switched)FCU to feed it. Is it likely to need heatproof cable like you'd fit on a storage heater, or will standard PVC cable be okay?
Also, if it is in the bathroom, would it be better to have the switch & control unit situated outside the bathroom as I'd imagine that it'll be a pretty small room, so might struggle with zones!?
I always say that "You don't know what you don't know..." so apologies if I'm asking daft/obvious questions, but I figured it was best to arm myself with all the information before I go out!
Many thanks in advance for any advice/guidance.
