Advice needed for garage power job | on ElectriciansForums
Discuss Advice needed for garage power job in the UK Electrical Forum area at ElectriciansForums.net
Plymouth
Advice needed! Ive been to see a job for garage power, the previous electrician has taken a 4mm on a 32amp B MCB protected by a 30mA RCD. But hasnt done anything with, apart from the fact there is no protection and its T&E all straight forward. My ownly question is do i gland straight into a socket and then have a fuse spur to supply a light OR can i install a 2 way board protected by a main switch or does it need to be a RCD main switch.
Why didn't the original Sparky finish the job???
What do you meant by no protection?
What protection do you think a main switch will provide?
Do you understand what an RCD is, how it works, and how it will work if you install another one in series with the existing one?
i would where it comes through the brickwork on house straight into ipbox sealed to allow swa via a cantenary wire with metal zips into either a small consumer unit dont forget to check whether you need to slam a rod in as tt for external outbuildings, you wont need rcd board in here if its already protected at source due to which trips first,
As in twin swinging in the air.
I do indeed understand adding an RCD in series work. I was just asking if youd fit an rcd again in the garage
[automerge]1578155382[/automerge]
Thanks mate, customer wants in buried, but everything else is spot on thanks mate
[automerge]1578155448[/automerge]
As soon as you contain it you can no longer use a 32A protective device. I would pull back into the house then use swa from this point.
Thanks mate
Reply to Advice needed for garage power job in the UK Electrical Forum area at ElectriciansForums.net
He said something about a fused something as the lights hardly take anything .. I told him was mostly cordless tools so just chargers ..told him...
