Advice needed on consolidating av and coax cabling alongside five 240 volt main lines | on ElectriciansForums
Discuss Advice needed on consolidating av and coax cabling alongside five 240 volt main lines in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
M
Markie Mark
Hi,
I need to rewire our Sky Box and CCTV System and I wish to use the existing conduit which currently houses five 240 volt main lines running for about 30 feet.
I'll be hoping to consolidate in this same conduit Ethernet cabling x 2, RJ-11 x 1, AV Cable x 2 and Sky Coax x 2. I am concerned about electromagnetic interference and therefore wondered if anybody has a similar setup running smoothly?
Many warm regards.
Re: Advice needed on consolidating av and coax cabling alongside five 240 volt main l
Power and signal/data cable should not be grouped together in the same conduit. From memory, I think the recommended separation distance is 350mm if comms cable is unscreened.
Yes, i'll run another conduit. D.Skelton recommended a uniform spacing of 350mm. I'll probably run conduit along the other side, away from power lines, I thought it would save time using existing conduit but I now understand that this is not practicle.
Thanks all for your help.
Reply to Advice needed on consolidating av and coax cabling alongside five 240 volt main lines in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
