Advice needed on two way switch | on ElectriciansForums
Discuss Advice needed on two way switch in the Australia area at ElectriciansForums.net
W
wilkyduch
Replacing a two way switch cover I’ve lost my note of the correct wiring on one of the switches.
Switch 1 has:
Grey to Common
Brown to L1
Black to L2
The wiring in place for Switch 2 has:
A single red wire
A yellow and red wire twisted together
A blue and black wire twisted together
My questions are:
Which colours go where in switch 2 And for interest, why does switch 1 have 3 wires and switch 2 a total of 5. What do the 2 additional wires do ? Why wouldn’t the colours in both switches match.
Thanks ever so much.
Switch one look like it's the end part of a 2 way light circuit and Grey, is your common or LINE and the black and Brown are the strappers.
Switch two is Red Common/LINE with the Yellow and Blue as your strappers. The Red and black are from your light and go with the strappers.
The two different colours are RED/BLACK and RED/YELLOW/BLUE are pre colour harmonisation and maybe 7 years old. The BROWN/BLACK/GREY are the new colours.
[ElectriciansForums.net] Advice needed on two way switch disconnect the lot bell them out and start again
Reply to Advice needed on two way switch in the Australia area at ElectriciansForums.net
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
Furthermore, as the left hand switch will currently not do anything, I'd try the loose brown in here:
