Advice needed on wiring for a log cabin | on ElectriciansForums
Discuss Advice needed on wiring for a log cabin in the UK Electrical Forum area at ElectriciansForums.net
Ireland
Hi guys,
Me and my partner have recently decided to build a log cabin at the back of her mum's house.
The electrician that the company's working with, is planning on using a 316 swa as the main power cable, but I have concerns as the cabin will be used as a permanent dwelling for a while and we'll have to fit an electric shower.
Now I'm thinking, we'd need something that should be able to handle at least 20 kw power draw to be on the safe side.
I'm not an electrician but based on my limited knowledge we'd need something rated for at least 90 amps.
Please note the cable will be buried and around 25 - 30 meters in length.
I'm out of my depth here so advice and a second opinion would be greatly appreciated.
Also, they quoted us ÂŁ720 for the wire itself which seems a bit steep?
Thank you!
90 amps? What are you planning on growing in there?
Confirm with your electrician how he has worked out the maximum demand. If then your still not satisfied get further quotes from other electricians.
Whos digging the hole? Whats the earthing system in the house? I take it will have electric heatong for the power ypu describe?
They're doing the digging and everything. I'm not sure about the earthing system, the house was built in the 70s.
Yes we're planning on going with electric heaters as gas would stretch our budget considerably.
If you need a supply that big then you'd better get in touch with the DNO and arrange to have a new connection brought in to feed this log cabin rather than try to run it from an existing supply.
How did you arrive at a demand of 20kW after diversity? Considering the average house will run quite happily on about 4kW that seems over the top!
I just roughly estimated the maximum demand with the heaters on during winter and shower running at full + appliances.
I'm not 100 % sure if that's how it works exactly that's why I'm asking if that particular cable would be adequate.
Thank you!
Thank you!
Tell the spark what you want and let him design it.
Cable should be about 250 at the absolute most. He might have included for rods in that orice and labout, wouldnt know without seeing the quote
The labour is part of a different quote but the rods are most likely included in that.
All in all it amounts to ÂŁ3850 for everything including labour / switches / sockets / fuse board etc
Was surprised as I expected the electrical work to cost less than the plumbing.
I did tell them exactly what I wanted and they did design it based on that.
It's very convenient for us to go with them, as they can take care of the plumbing and everything as well.
They assured me the 16 mm is adequate for what we need, I just wanted another professional opinion on the matter as time is of the essence, although I know details are very limited.
I really appreciate your help, thank you
Reply to Advice needed on wiring for a log cabin in the UK Electrical Forum area at ElectriciansForums.net
Thank you for another very helpful response. Just to assure you we are saying the same thing, I was referring to the 2.5 on 20A radial which I now...
It's the policy on this forum not to give step by step advice. If you have an understanding of wiring requirements you will not have any...
