Advice needed please | Page 2 | on ElectriciansForums
Discuss Advice needed please in the The Welcome Forum area at ElectriciansForums.net
I believe the gravel was to help prolong the life of the primary material (most likely felt) by providing mechanical protection and also UV protection by preventing the sun hitting the roof surface.
Edit:- If you're in my neck of the woods (Cardiff, Newport and the areas in between primarily), drop me a PM if you need some assistance with the electrics.
If there is no danger of anyone touching it or working with it and you have isolated it putting a couple of 15a connectors on it will be fine as a temporary measure
Thanks Matthew, the room needn't be used at all so no danger of it being touched, just been worried about the fire hazard.
(Happy St Patrick's Day!)
Reply to Advice needed please in the The Welcome Forum area at ElectriciansForums.net
Furthermore, as the left hand switch will currently not do anything, I'd try the loose brown in here:
B
Do I need to bother with traps at all?? I'm building a new off-grid house. I have a septic tank exclusively for WC's, but the bathroom has its own...
BuilderDan
B
