L Walton
Hi everyone. I'm not an electrician but joined the forum to ask for some advice on using terminal blocks. My old flat roof has started leaking and water was coming in through the ceiling switch and travelling down the pull cord - although it clicked on and off the bulb wouldn't turn off. I removed the fuse for lights in my house straight away and took the entire switch off to allow things to drain and dry out. I have hopefully made the flat roof watertight for now but it needs to be replaced which will take a while to organise. I want to isolate the wires with a terminal block so that I can put the fuse back and have lights everywhere else. So please can you tell me which amp terminal block I should use and any other advice on making it safe would be gratefully appreciated. Many thanks
