2k2
Hi Please forgive me if this sounds simple, but i have just started on my own,whilst in the past i just installed from site to site and the boss did all the testing, so know iam on my own i have to do the certs and pir's and its a new world all over again.
so i was doing a pir yesterday every thing was going fine until i got to the ring main first it was cabled in two sizes at the ccu but at every socket it was 2.5mm so somewhere there must be a join.
when i did the continuity of the ring test's most the readings where over 1 ohm should this be close to 0?
then when i did the IR test i got 180 which slowly went up to 297 on L to Pe, Pe to N i got 180 which again slowly went to 276. put on L to N i got 0.02.
I looked in the OSG and it looks like it would fail but could anyone tell why this might be.and would it be ok if it was on a RCD? the Z's was 0.32 and R1+R2 was 0.22
Also they have afew sockets which has a plug on the end of flex and then pluged into the nearest socket!! and some sockets have been spured off useing 2.5 flex. what would you recommend i report for this!!
Any help would be great
