Hi
Need some advice.
Been asked to quote on a job to replace a CU in a garage from a 2 way to a 4 way with RCD.
Existing is 2 sockets in garage plus lights, they want to add outside lights and power and lights into shed(approx 20 metres).
The previous occupants fed the garage off a spur from house taken off the back of a double socket, main CU and meter is at the other end of the house and front and back is all landscaped .
Do I:
a) Put in a FCU and junction box and run everything into that and use the RCD on the main CU
b) Put in a RCD CU and connect all circuits to CU
c) any other option
d) walk away
Need some advice.
Do I:
c) any other option
d) walk away
