P
Philipsg2
I am hoping that someone can clear up what i actually need to get done for my house electrics.
I need some extra sockets, a light fitting and the sitches changing. I have had 3 electricians out this week all which have told me 3 diffferent things. All have emailed mw with brief recommendations -
Electricial 1 ) - A old style fuse noard is currently installed with no RCD protection, i would recommend that a split load board is fitted with full RCD protection. No work can be carried out until this upgrade has been carried out.
Electrician 2) - After visiting your property we can carry out the works discussed under minor works and issue a certificate. We would recommend that a new Distribution board is fitted at some point as there no RCD protection.
Due to the lack of space we would not get a split load Distribution in the space. We would installer a smaller single board with RCD protection. I would also recommend a full electrical inspection as the wiring and some of the accessories look to be many years old.
Electrician 3 - I can carry out all of the work we discussed at your house. I would recommend that a new board is fitted at some point as you are still on the old syle fuse board. There is also a lack of RCD protection which does need to addressed.
So who is right?
I am just the customer??
Thanks Philip
So who is right?
Thanks Philip
