newbie9857
Hi I have recently wired a basic fan extractor to a pull cord bathroom light. I managed to get it working but I need someone to confirm the theory behind what I have done and I have some questions. Any knowledge will be appreciated.
The fan is a basic fan, it has 3 wires. Blue, brown and yellow/green.
The light switch is a 3 way switch. It has 2 red wires, a blue wire, a yellow/green wire.
There is also 3rd red wire in a connector block.
I connected it like this:
Red wire 1 in common port.
Red wire 2 in L1 port.
Fan blue wire to the L1 of the light swtich.
Fan brown wire to connector block with red wire 3.
Fan yellow/green wire to ground terminal in light switch.
Questions I have:
1) The light switch has a ground terminal screw so I connected the yellow/green wire from the fan to this but as the fan is plastic and does not have a ground terminal screw do I need to connect it at the fan side or the light switch side? I did put the wire around a screw in the fan just in case but not sure if this correct.
2) The blue wire from the fan is connected to L1 of the light switch with a red wire also in L1...is this correct?
Questions I have:
