M
Martin Watts
First things first, I'm not an electrician! I'd call myself an advanced DIYer which might well be a swear word on these forums!
I'm aware of the regulations around not doing major work in your house unless you're qualified but I'm not sure exactly what I can and can't do and was after a bit of advice.
The extractor in our bathroom has just broken. I've bought a new inline shower light one to fit in the loft from Screwfix (bathroom has no windows or outside light source) and have read that it is now best practice to add a 3 pole isolator outside the bathroom high up on the wall (there isn't one there at the moment). Also I know that the new regulations say you should follow manufacturers instructions so I also need to fit a 3amp fuse and again, best practise for this is to fuse down the fan and lights from the main circuit? There is no FCU in place for the current fan, its run directly from the light.
So am I allowed to do this in my house myself? Am I right in thinking that the Bathroom and kitchen are areas that I'm just not allowed to touch?
I'm perfectly capable of doing this work myself, but don't want to invalidate any home insurance should the worst happen or cause issue when i come to sell the house.
I've also replaced an immersion heater timer, element and the wire in between the two myself. Is that allowed? It's situated in the airing cupboard.
I've also taken a fused spur from a kitchen socket and run it down the garden (10m in armoured cable) to the shed to power a tumble dryer, external socket (for a mower) and another fused spur from that for a light in the shed too. Again, is that allowed? I would consider this a safer option that what I was using before which was a long extension lead! But as it's permanent I wanted to check the regulations.
Thanks in advance guys.
