View the thread, titled "Advice on connecting flat with different cold and hot water supply" which is posted in Plumbers Forums on Electricians Forums.
My residential block has 5 floors above the ground floor, the 5th being the top floor (loft under the sloping roof) where one side has the communal cold water tanks for most flats and a communal hot water cylinder for most flats as well. The other side of the 5th floor has a tiny studio, where the the cold water is supplied from a tank above the studio's roof and the hot water is supplied from an adjacent immersion cylinder serving that flat alone. If I get rid of the cold water tank and immersion cylinder for that flat, can I use the building's communal cold water tanks and hot water cylinder? I would use a pump. The kitchen cold water would as is.
Continue reading...
Reply to the thread, titled "Advice on connecting flat with different cold and hot water supply" which is posted in Plumbers Forums on Electricians Forums.
B
BigTomorrow
B
