G
Gavsparky
Hi all, I'm having a discussion about the correct NICEIC Certs to produce on a job. The scenario is, we have carried out works out on a big commercial site which include full rewires on three separate distribution boards each being 18 way 3 phase, the main SWA feeding each DB has stayed also the same DB we have just rewired final circuits. There is quite a number of DBs all fed from a main section board that have not been altered in any way also these were not required for condition reports. The question is would you produce a separate certificate (new installation) for each of the three DBs or do a certificate for one and then put the other two on continuation sheets? Appreciate all replys cheers
