H
hermitish
Hello all,
Registered in the hope that someone here would be able to give me some advice on a piece of equipment we have where the motor appears to be causing issues. It's a hay bale elevator, basically a conveyor belt that is driven by an electrical motor. It's been standing for a good few years but we've recently tried to get it going and although it runs and everything appears to move freely the motor cuts out after a couple of minutes, i've tried running it without the drive belt so that there is no load on the motor and the same thing happened so i think that the issue is either in the motor or the control box for the motor. it's a single phase 240 volts running off a standard 3 pin plug.
The motor turns very freely by hand and starts OK, have not stripped it down any further than taking the back fan guard off to clear our some cobwebs but it seems in good condition.
The control unit, has the name Brook Control Gear on it, is a little beyond what i am used to. Externally it's an on/off switch; internally, from the looking around i've done on-line, a magnetic switch with adjustable over current protection, in the bottom right of the picture by the blue plastic bit for the off switch and it's already set to the maximum 6 A. I've attached some pictures with labels attached to the unit etc.
Questions i've got are: would there be some issue with the motor that would cause it to draw too much current an trip the safety in the control box without it being obviously hard to turn by hand, in short - should i open up the motor to have a look on the inside? The other option is that there is some problem with the control unit, in that case would there be anything i could look at to confirm the problem and if not does anyone know where i would be able to find a replacement control unit?
Thanks in advance.
Thanks in advance.
