gazdkw82
so I have an ip rated double socket outlet on the side of my decking. It's spurred from a double socket workshop which is fed from the house CU (SWA)
Iv fitted some decking lights which have a standard socket fitting. I'm looking at options to have the lights automatically turn on around 6pm-9pm in the evening.
There isn't enough room within the socket outlet to have a standard socket timer.
Is there some kind of exterior timer that I can install online between the lighting transformer and the 3pin plug? I can only seem to find a socket outlet fitting with timer included which would mean replacing the existing outlet.
For the hassle/cost I'd be tempted just to replace the unit. Only £30 or so.
Any timer you insert before the existing socket will obviously time both sockets.
You could just plug in a lead to another twin single IP box and put a timer in it feeding a socket (or a double box with the timer socket double gang)
Not enough room I suppose for something like this and the plug?
Still too big to use on those ip rated socket outlets. It's a squeeze to close them shut with a standard uk plug
Single Outdoor Weatherproof Unswitched Socket IP66 (Large Housing) WP23L
Ideal for use with large plugs, transformers & RCD adaptors!
gazdkw82
leicester
United Kingdom
Electrical Engineer (Qualified)
Advice on exterior timer control
Electrical Course Trainees Only
gazdkw82,
Richard Burns,
