simsum
I'd be grateful if anyone could give me some advice.
I removed a single light and found three cables attached - they were old colours. The cables also fed the lounge lights where there is a two way switching.
I've connected the new four spot light in the study in exaxctly the same way as the previous single light was wired ( three reds into one terminal, three earths into one terminal and two neutrals into into one terminal and one neutral on its own). The problem i have is that the lights will either stay on in the study, trip the rcd if the switch is turned on, the lights in the lounge wont work or nothing will work.
I'm assuming that for some reason the original configuration will not work with the four spots on a single bar.
The spots came with a four terminal block with live going to one side, neutral the other and earth in another.
Any advice would really be great and get me out of the dark ages.
