Hi guys,
I would just like to ask if any one could look at my test procedure off the top of my head and give any advice or pointers or whether its too long winded or short. got an exam in 2 weeks so trying to drill it in to this thick skull
Many thanks
Safe Isolation has been carried out:
Many thanks
- Seek permision , Inform client and relevant persons that test is about to be carried out
- Make area safe by putting up barriers and warning notices
- Disconnect lamps and link out or disconnect other sensitive devices that may be vulnerable to test voltages
- Select an insulation resistance tester, Check tester is calibrated, leads show no sign of damage, and that tester is functioning.
- Select the Megaohm range set at 500V DC
- Identify circuit to be tested, and test between Live - Neutral and record result. Do the same test between Live - Cpc and Neutral - Cpc record results.
- Expected result a minimum of 2 M/ohm.
- Reinstate circuit
