Advice on rewire method | Page 2 | on ElectriciansForums
Discuss Advice on rewire method in the UK Electrical Forum area at ElectriciansForums.net
`Carlisle
Hi all, just got a property for myself and looking to rewire it. Have only every rewired houses with old floorboards but this property has the wayrok sheetboards. Anyone got any experience of of the best way to lift without ruining them too much? Thanks in advance
[ElectriciansForums.net] Advice on rewire method
I have see these in the wholesalers, not had to use them ny self but they look a handy bit of kit .
https://www.amazon.co.uk/Silverline...39&hvtargid=pla-421739994949&psc=1&th=1&psc=1
If you are going for one of these don't get the silverline cheapy one. I did and the hole size was not a snug fit for the plug, the rebate being too wide and too deep. I took mine back.
The Armeg sets are spot on but a bit pricey. The newer cutters have a cobalt mix to the cutter for a longer life. Much better fit.
They do two sizes, I went for the larger one to accommodate my fat hands.
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
How much would you say it would cost for a 3 bed property? Never used them, always seemed to priceyin the wholesalers
apart from the damage you'll inevitably do to the flooring, you'll find wet-pants has run his spaghetti tight up to the underside of the floor and it could route anywhere. you'll end up with broken, soggy wet chipboard,and the ceilings below will probably need replacing also. only time i've gone in through that type of floor, I've got the customer to cut it, and take all the responsibility. ended up it cost him another ÂŁ200 to repair the floor.
Or work harder, save your money and stay away from Barrat Houses.........
Round here it's the new build lego boxes that are the most pricey
Depends if the joists are open or closed. If open I would consider this as a method, if the joists need drilling I would consider other methods. I use this tool usually for small jobs where only a few holes are required.
I think Tel's method of not rewiring is the best one to be perfectly honest. Asking for a possible nightmare.
Another vote for having some of the ceiling down, rather than trying to remove the chipboard (or whatever it is) flooring. The plasterboard will come down easier than trying to get the floor up.
Bet the ceiling is artex anyway. Easier to get your pipework in (plastic as well). Quick patch up, and get the ceiling skimmed. Sometimes this type of flooring is part of the structure of flooring joists, you never get it back the same.
Reply to Advice on rewire method in the UK Electrical Forum area at ElectriciansForums.net
About 10 years ago I spent a while working on a rewire of Tewkesbury Abbey, all mandated as MICC and anything on show we had to spray with a...
Yes still see the odd red white and blue out in the wild, usually without cpc, iirc that colour code was only used for a short time...could be...
