R
Rich18144
Hi All,
I was hoping you'd be able to advise whether or not this is as simple a repair as it looks to me? I have some electronics experience, but in a thoroughly amateur capacity and nothing on any home appliances beyond re-wiring a plug.
Our shower has made a popping noise, followed by a odd burning plastic smell. I took off the Shower casing and found the scene in the images below:
Looking at it, it would appear that I just need to replace the blue wire that has been damaged? In mind my mind it only requires a replacement Live wire, soldered to the circular black disk and screwed into the electronic point.
Would I need to get electrician in for this? Or is it as simple as I think?
Thank you for your time,
Rich
Rich
