Advice on surge protection | on ElectriciansForums
Discuss Advice on surge protection in the UK Electrical Forum area at ElectriciansForums.net
IW
I've got a fair bit of computer equipment at home which I need to protect as best I can. I use surge-protected extensions and these have been needed a couple of times. At least I think they have, the warning lights have come on, presumably because they've diverted a surge once too often.
Is it worth having an SPD that covers the incoming mains fitted and, if so, how much would it cost? TIA.
If you do not need all the electrical installation covered then don’t. If you do need more than what you currently have covered then do.
It all comes down to the value of what you want to protect and the cost of installing.
A Type 1 SPD will cost around £500 installed worst case.
The MK spd socket might be an idea, especially as it beeps when it's failed. Maybe I should get a quote from the local sparkies and see what the score is regarding an overall spd. Thanks.
Reply to Advice on surge protection in the UK Electrical Forum area at ElectriciansForums.net
It is not a brand that I know, but on the appearance it would look like a good enough choice for most situations where you do not expect a direct...
From the title and first post it is not clear whether you are looking to install surge protection or a lightning protection system (LPS) or is it...
