V
vickery1971
Hello All,
I am after some advice as I have the opportunity to do some work (upgrading old consumer units) on a couple of empty flats for my next assessment. The trouble is I have never done a Board change in flats before (as I am only a novice), and as usual they are sub boards running from split three phase supplies via old metal box isolator switches with 60A fuses. The cable from the isolators to the boards is 10mm T&E and from the look of it someone ran a 10mm earth to each board too.
My questions are, how do I go about testing ze (it’s a tncs system) as all the earths from all the flats go to a Henley block in 10mm then one 16mm back to the service head, obviously I wont be able to cut everyone’s power to take all the earths out to avoid parallel paths, so any help here would be greatly received?
Next thing is my MEC to the board will only be 10mm, is that a strict no-no or do I just write that on the cert?
Thanks in advance for any advice you can give.
