Advice on testing | on ElectriciansForums
Discuss Advice on testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
R
Russ the spark
What form do i need to need to use if i replace a mains board. and also there is no bonding to incoming water and gas and customer will not pay to have it done. what do i put on test certificate. cheers
If the customer won't have the 'Bonding' installed/renewed, then you don't do the board change - simple as.:)
6. Main earthing and bonding and
meter tails
6.1. The installer must verify, as a minimum, that:
a) the main earthing terminal of the installation is
connected to an adequate means of earthing
via a suitably sized earthing conductor,
b) the main protective bonding is adequate, and
c) the meter tails and the distributor’s equipment
have adequate current-carrying capacity.
Note. Some electricity distributors have requirements regarding
the earthing conductor, main bonding conductors and meter
tails that exceed the requirements of BS 7671.
6.2. If any of conditions 6.1 (a), (b) or (c) is not met, the
customer should be informed that upgrading is required.
If the customer refuses, the installer should not proceed with the replacement of the consumer unit.
You beat me, Len;)
Reply to Advice on testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
A
What torque is a gas meter test nipple tightened too? What torque is a gas meter test nipple tightened too? What torque is a gas meter test...
Anthony1128
A
M
Heatrae Sadia multipoint 50 issue? Hi folks I’ve never installed or maintained the water heater above but today I’ve isolated the cold into the...
macka09
M
