Advice on Trunking main supply cables on exterior walls | on ElectriciansForums
Discuss Advice on Trunking main supply cables on exterior walls in the DIY Electrical Advice area at ElectriciansForums.net
M
MaNdlovu
I would appreciate some help on the appropriate way to deal with a main electrical cable which runs along the exterior wall of a wooden walled residential building which is to be externally insulated with thick expanded polystyrene, rendered on top. Can the cables be covered with trunking and then the insulation over the top of that? Are there any regulations dealing with this issue? Thanks in advance.
Reply to Advice on Trunking main supply cables on exterior walls in the DIY Electrical Advice area at ElectriciansForums.net
dreadful, I couldn't sleep at night after that install, it may just about pass but the quality of work is substandard IMO
An example of the long term race to the bottom of quality of work in our industry, IMHO.
