Advice on what multi meter to purchace | on ElectriciansForums
Discuss Advice on what multi meter to purchace in the UK Electrical Forum area at ElectriciansForums.net
E
Electri-kate
Hi new to this forum. Hope I have posted correctly!! I am looking to go out on my own as a domestic electrician. Just after some advice on what's the best multi meter to get?? Thanks in advance :stooge_curly:
Get in touch with forum sponse "test meter" - speak to them and they do have a very neat comparision matrix.
My advice is to buy once and buy wisely - apart from a vehicle this could be you most expensive purchase and needs to be a good one.
If you are tempted to buy 2nd hand, remember to allow for calibration (ÂŁ60 - ÂŁ80) as this is required yearly and unlikely to be sold with the unit.
Hope this helps.
for me as a dumbass sparky I use the simplest meter I can find, I have a fluke 10 which only does ac dc and resistance/continuity but that's all I need, I recently bought my apprentice a fluke 113 which is the modern alternative and this seems as good(simple) in my opinion
fluke 113 test equipment | eBay
Have a gander at the Megger range of smaller multimeters. They are good quality,easy to use,and have the back up of a large outfit. Also,don't forget little extras such as a sturdy case and clip-on crocs etc. Never underestimate the value of a good,hand-held multi,they have earnt me considerably more over the years,than their fancier brothers! Go and spend time researching a decent one,spend time playing with it,and then spend what it will earn you. Good luck.
I really like the look of those, have been thinking about buying one for a while. Would you recommend it?
Yeah, it's spot on. Auto ranging so so simple your nan could use it and the current measuring "u" at the top might not be quite the most accurate but had proved useful quite a few times. You might get the t5-600 cheaper (600v rather than 1000v)
Megger do a DCM330,that has all above functions,but has a built in "Voltfinder" at the tips of the clamp jaws. It is by far,the best voltfinder i have used,and has standard plug in 4mm leads,so extras like crocodile clips etc are easily fitted. The only down side is you cannot hang it round your neck by the leads (as so many seem keen to do,maybe it's fashion?) as they are push-ins.That said,there is nowt wrong with the T-5 range,good kit.
My own lovely life partner has had a Blackberry (device NOT fruit) for a year and can't drive it,but the other day she got me good....i left some test gear out in the lounge,after a sad nights playing about,and she told me she had "tidied up" coz we had pals over from Newzealand,so i was concerned as to their condition,and asked what she had done..."i put three away" i asked which,"Two that looked like crap mobiles,and one that looked like a radio from the war..." mmmm 2x multimeters and 1x 1720...marvellous :bow:
Reply to Advice on what multi meter to purchace in the UK Electrical Forum area at ElectriciansForums.net
Thank you to littlespark for clarifying my mumbo jumbo. Just to say that being on a dual tariff means you will typically pay more for electricity...
The last couple of de-loops that I have been involved with had the single phase supply replaced with a three phase cutout (as I believe the DNOs...
